dixie Posted April 30, 2005 Report Share Posted April 30, 2005 Anyone got or riding a 4t sherco, Do you ever use the choke ? Mine seems to start first or second kick without it from dead cold,on the couple of occasions i have used it it flooded. turned it off and a couple of kicks and it fires up no problem ? Is this because the weather is warm ? When it is running it seems fine and just keps getting better Quote Link to comment Share on other sites More sharing options...
marky g Posted May 1, 2005 Report Share Posted May 1, 2005 You lucky man to have such a bike..... Quote Link to comment Share on other sites More sharing options...
jjwhite Posted May 1, 2005 Report Share Posted May 1, 2005 what do the new sherco 4t's run like? i have just come off a mont 4rt and loved that, although it could be a bugger to kick over, and oiled plugs up like nobodies business Quote Link to comment Share on other sites More sharing options...
dixie Posted May 6, 2005 Author Report Share Posted May 6, 2005 Mine burnt a bit of oil for the first couple of hours only a puff the motor is just getting stronger and stronger; four strokes get a bit of upper cylinder lube from oil left in the bore and through the valve bushes , the sherco definitly has the edge over the mont on bottom end ,it is a real tractor off the bottom,cant wait to give it some Quote Link to comment Share on other sites More sharing options...
re500 Posted May 23, 2005 Report Share Posted May 23, 2005 Dixie, recieved my 4T last week. Yes, i need the choke on to start it, also needs to be left on for a minute or so. Engine dies if i take the choke off too soon. Obviously choke not need when warm. Quote Link to comment Share on other sites More sharing options...
