Txt 200 Big End/crank
carl90
Hi All,
It's looking rather like im going to need a new big end bearing for my txt.
Does anyone know what my options are (UK)?
Can you buy main bearings, rods and big end bearings seperately?
Is the crank even rebuildable?
Are complete new cranks available? and if so how much £££ am I looking at?
Any help would be much appreciated,
Cheers,
Carl Newbigging
You need to buy a rod kit , top bearing ,piston clips,main seals, center case gasket, base gasket, and clutch gasket from a gas gas source. The main bearings should be available at a better price. You did not mention year, but should be the same for all models. Not a cheaper way around it at this point unless your dealer can also do the rod rebuild. You could replace all seals, and other parts also but is just preventive for future use.
