sina Posted July 14, 2012 Report Share Posted July 14, 2012 (edited) The problem I have with my bike, is only shifting down from gear 5 to 4. When I shift from 5 to 4, it gets stuck in between, and no amount of play, makes it fall in place. I know shifting from 5 to 4 is tricky (be at the right speed, and give it a light touch), but mine is extremely difficult, what could be the problem? Sina Edalat, Gas Gas rider from Tehran, Iran Edited July 14, 2012 by sina Quote Link to comment Share on other sites More sharing options...
tankygsy Posted July 14, 2012 Report Share Posted July 14, 2012 Assuming all setup correctly (you can adjust the gears a little, there is a video somewhere) id suspect a Worn dog ring or faulty shift fork if it's doing it from 5th to 4th and not 4th to 5th. Possibly wear on the shift drum also. Not particularly difficult to fix but it's an engine out job, head off etc to give it a thorough inspection. Quote Link to comment Share on other sites More sharing options...
sina Posted July 15, 2012 Author Report Share Posted July 15, 2012 What will happen if I keep riding like this? is Gas Gas known for it's fragile gear box? Quote Link to comment Share on other sites More sharing options...
neilh Posted July 15, 2012 Report Share Posted July 15, 2012 yes, common fault. faulty connection between the handlebars and the footpegs 1 Quote Link to comment Share on other sites More sharing options...
dadof2 Posted July 15, 2012 Report Share Posted July 15, 2012 I think 4th to 5th and 5th to 4th shifting problems are an early indicator of a needle roller bearing on a gearbox shaft beginning to fail. Better sorted sooner than later before it damages anything else. Cheers Quote Link to comment Share on other sites More sharing options...
sina Posted July 17, 2012 Author Report Share Posted July 17, 2012 are the parts I need for fixing it, specific to Gas Gas? cause I live in Iran and have access to very limited parts. Also my local mechanic is an expert who works on moto cross, but has never touched a trials bike, will he be able to figure it out and fix it??? Quote Link to comment Share on other sites More sharing options...
lowbrow Posted July 17, 2012 Report Share Posted July 17, 2012 (edited) Hi Sina, you or your mechanic may find Jim Snell's excellent videos helpful. Look here http://www.trialspar...om/youtube.html and scroll down for the technical video's. He runs through a complete motor strip down and explains how to set up the selector adjustment. Edited July 17, 2012 by lowbrow Quote Link to comment Share on other sites More sharing options...
laser1 Posted July 18, 2012 Report Share Posted July 18, 2012 http://www.youtube.com/watch?v=A80n7zq80n8&list=UUuuOSB4N2iUkW8dbbH7HJpw&index=2&feature=plcp The procedure for adjusting the centering spring is at 6:30 minutes. You want to check the fused link as well. This is all located under the clutch hub. see part 1 and 2 of pro engine video's as lowbrow suggested on the utube channel. Quote Link to comment Share on other sites More sharing options...
laser1 Posted July 18, 2012 Report Share Posted July 18, 2012 Your mechanic will find the motor very easy to work on, and there are many procedural tips and adjustments in the video that are invaluable. Unfortunately, the parts are VERY specific to Gas Gas. Quote Link to comment Share on other sites More sharing options...
sina Posted July 19, 2012 Author Report Share Posted July 19, 2012 Unforunatyely for me, you tube is one of the many sites, tha's blocked here. I really rather not touch it, and just ride despite the difficulty of shifting, but I just need to know if it will lead to another more serious problem? and since there are no parts here, I don't want to have it opend, and not be able to get fix, and possibly have it worse than before... Quote Link to comment Share on other sites More sharing options...
lineaway Posted July 19, 2012 Report Share Posted July 19, 2012 Dad of 2 has got it correctly diagnosed. After just seeing the same thing happen to a 2010. You need to have the tranmission inspected now before you actually start beaking gears and need a total replacement. Yes it will just destroy it self if you choose to ignore it. Out of curiosty is this the Econo model? Quote Link to comment Share on other sites More sharing options...
sina Posted July 21, 2012 Author Report Share Posted July 21, 2012 (edited) on top of the shifting down problem, now I realized the coolant is mixing with the oil. I wish I had never bought a damn Gas Gas, it's too fragile (only looks nice), I would have been much better of with a Honda Montesa or something. did I mention I only had 5 trials on my new Gas Gas? Edited July 21, 2012 by sina Quote Link to comment Share on other sites More sharing options...
ham2 Posted July 23, 2012 Report Share Posted July 23, 2012 Get it sorted,the Pro main bearings are lubed by that (emulsified) transmission oil. Quote Link to comment Share on other sites More sharing options...
