Rear Wheel Bearing Life?
" it should not matter how tight you do up the wheel nuts as this will not load the bearings "
Actually you would be quite surprised how much distortion there is when a bolt is tightened, anyone who has tried to unscrew a fork cab before loosening the triple clamp will attest to this, it won't even budge, and that's a hard steel tube squeezed by a couple of 6mm bolts
the only reason a bolt will tighten is because the threads stretch and lock into the nut, etc etc
So yes the spacer will compress if over torqued and side load the bearing
This means more torque as a compression force can be applied to the threads of the axle than the alloy spacer can cope with. The hard steel races are forced hard against the soft alloy spacer in the hub and will squash it longitudinally.
Bottom line - don't over tighten your axle nut!
Edited by pindie
This is why we have torque specs and torque wenches.
I used to hear the saying "tighten it as tight as it will go then one more round". That was my Dads philosophy and he broke a lot of bolts.
True. It's the same at the front axle, which is usually overtightened as the rider does not realize the axle pinch bolts secure the axle, not how tight it's screwed in.
Jon
