Stator Problem Beta 125 08
chasmitch
hi there just wondering if anyone can help,
i have a beta 125 2008 and the stator has gone,
i have just sent it off for repair/rewind ,
and i was worried that when its done and i run the bike whats the chances of it going again ?.
is it a fault with the bike or a problem with the original stator,
i have read many topics concerning this and have also checked the kill switch as described in other topics and it goes to the earth at the coil,can anyone enlighten me please
i am new to this forum and have had a good read through a good few of the posts and i must say that i am impressed with all the answers and help available and am thanking you in advance of an answer to my question
charlie
Hi Charlie
Typical Rev 3 problem with the stators going. I had 3 stators go on my Rev 3's. Each time were genuine replacements from Beta. One only lasted 2 months! The last one supplied was in 2010 and seemed by then they had solved the new stator reliability/supply issue.
The symtoms ranged from motor totally stopping and not going again through to motor stopping, then when cold it would start again and run ok till it was hot again.
I didnt try a rewind so you may be OK if they upgrade the stator windings with better insulation etc.
Good luck
Grumpyget
A company now based in the south east but has a name from the west country is a windings specialist. They use thicker wire etc so should last longer.
Take the cover off after washing to let it dry out. Don't worry about it during the days riding but they seem prone to condensation even if you seal it right. Just wash the casing if your not a cleaning freak, undo the three bolts and leave to air.
A blast of GT85 won't hurt.
From what I have had with mine it is impossible (unless lucky) to get no condensation in the cover. The windings rot from the inside out so you can't see it going wrong till it's too late. Air is your friend - use it!
thanks for the info i will definitely air it out,so do i assume the problem was with the stator and not with using the kill button,i am now waiting for the stator to come back from west country windings, they were very helpful and i recommend them to others
  • 1 year later...
My 98 beta techno lampkin rep has started playing up running backwards and missfire very harsh kickback will play in the flywheel in and out be the issue?? change the mains and there will be no play do you guys think that will cure the problem thanks lee
