Evo Air Filter Box Shreaded Threads
henrik
Some of the brass threads on the air filter box are shreaded. I guess I´m not the first one to experience this. What solutions could be done regarding this?
The brass material is so thin I dont think i can either thread it a larger dimension or insert heli-coil. Only way with heli-coil would be to drill the brass away and put it in the plastic which i doubt will last long. Could try to do it in another piece of plastic and test the strength.
It would be nice if one could buy something made for this, some sort of insert with better threads but I don´t know if that exists.
Any ideas, what has been done before that works except buying a new air filter box?
Does anyone know what type of brass thing is used when they manufacture it and how it is inserted?
what you are thinking of is a rivet nut its a thread inserted like a rivet some body work shop garage or poss coach builders may have them or fabrication off road 4x4 specialist
You could look at this - it may help
Also, you may be better getting the aluminium alloy rivnuts - they pull in more easily than the steel or stainless steel ones.
Edit*** maybe use thin washers either side of the rivnut to 'repair' the hole...? Edit***
Good luck!
Edited by stecks
I would think very carefully before drilling through to the inside of an air box. If you do make sure whatever you have on the inside won't fit through your reed block. Nuts and other thingies don't mix well with two stroke ports and pistons.
Cheers
  • 3 months later...
Have you considered tapping the screw holes out to the next larger thread size? There should be enough material to tap the screw holes from 4mm to 5mm or 5mm to 6mm. Don't remember what size they are?
I just read the last post. I discovered you fixed it. Disregard my post.
Edited by liviob
