dougalthedog Posted July 25, 2012 Report Share Posted July 25, 2012 Trying to help a local lad with his TY175 No spark - checked plug, cap, lead, kill switch etc - suspect points or condenser. Have ordered new points, condenser, plug etc Can anyone post a link to relevant section of manual or give a step by step guide to fitting and checking timing. All my bikes have electronic ignition systems so any help appreciated Cheers in advance (pardon the pun ) Quote Link to comment Share on other sites More sharing options...
bruno21 Posted July 25, 2012 Report Share Posted July 25, 2012 Hi, It will most certainly be the condenser as the bike will go one minute and then just pack up . Best of luck. Quote Link to comment Share on other sites More sharing options...
dougalthedog Posted July 26, 2012 Author Report Share Posted July 26, 2012 Turned out the points had closed up ! Ive reset them and all is well (for now) 1 Quote Link to comment Share on other sites More sharing options...
tomch Posted July 27, 2012 Report Share Posted July 27, 2012 I 've had this problem 4 times running until I fitted a split washer under the screw and the emeried the points... Quote Link to comment Share on other sites More sharing options...
