Rev3 Stator Check
dave2
Hi all, my '06 REV3 270 is acting up sort of like the stator is starting to give up the ghost. How can I check this out with a multimeter? Or can I even check it?
Symptoms were misfire then no spark at all, cool for a bit and it would restart though it wouldn't rev much at all. Made it home and pulled the sparkplug, using a fresh plug to check for spark. It was very weak. After it cooled completely the spark was a bit better but still anemic.
Anyone have a test procedure?
  • 8 months later...
If I put a 12v test light on the red and black wire from the stator I get a nice bright light. If I put the light on the brown wire and the yellow from the stator I get about half as bright of a light. I also get half the brightness when I connect the light on the yellow wire and the ground. Is this normal? Thank you
