gazzaecowarrior Posted August 5, 2012 Report Share Posted August 5, 2012 Just picked up my little mont mh123. The guy I bought it off said that the revs build up without you touching the throttle to the point it's about to go bang. He thought it was an air leak so he had bought a new inlet rubber from carb to cylinder head but still the same problem. He had also bought a new needle as he thought the original was a bit scarred. I've literally just brought the bike home so I haven't even had time to look at it. Any ideas ? It does sound like an air leak to me. He also said that the motoplat ignition system won't cut out with a kill switch when the revs build beyond a point and you have to pull the plug cap off. Is this the case or do i just need a better kill switch ? The current one looks like an old bicycle bell. I want to be able to kill the engine as I don't want to be over revving a cold engine. Quote Link to comment Share on other sites More sharing options...
zerorev3rev4 Posted August 5, 2012 Report Share Posted August 5, 2012 most kill switches wont work on a singing engine , make sure there is slack in throttle cable make sure slide is in correct and is capable of sitting right down so you cant see any air through it if it still does it its poss the main crank seals prob best to give carb a good clean out and check air filter before attempting to start Quote Link to comment Share on other sites More sharing options...
gazzaecowarrior Posted August 5, 2012 Author Report Share Posted August 5, 2012 On 8/5/2012 at 8:48 PM, zerorev3rev4 said: most kill switches wont work on a singing engine , make sure there is slack in throttle cable make sure slide is in correct and is capable of sitting right down so you cant see any air through it if it still does it its poss the main crank seals prob best to give carb a good clean out and check air filter before attempting to start Thanks for that. I will give it a good inspection this week. I'm hoping it's not the crank seals but it maybe as the bike has been stood many years. Is it possible to replace the ignition side crank seal without splitting the cases ? Quote Link to comment Share on other sites More sharing options...
ducati996 Posted August 6, 2012 Report Share Posted August 6, 2012 You should b able to replace both crank seals without splitting case however i would not think crank seals would cause engine to run flat out think problem is more likely to be carburetor. good luck. Quote Link to comment Share on other sites More sharing options...
nzralphy Posted August 6, 2012 Report Share Posted August 6, 2012 NO NO NO NO. Do not pull off the plug cap. It will hurt like f**k and it could kill you. Take off your glove and hold it against the exhaust / tail pipe exit. Do not let go and push hard. Quote Link to comment Share on other sites More sharing options...
gazzaecowarrior Posted August 14, 2012 Author Report Share Posted August 14, 2012 It was the throttle cable all along !!! Quote Link to comment Share on other sites More sharing options...
big john Posted August 15, 2012 Report Share Posted August 15, 2012 An easy fix, but the simplest of all! Big John Quote Link to comment Share on other sites More sharing options...
