2004 Rev 3 Carb Setup For The Uk
dazzagreener
Hello iv had my rev 3 for a few months now and just doing some of the mods to the carb like brass tang level and changing the breather pipes.
I would like to know of there is a good set up for the uk
I have a 150 main and 30 small is this ok or is there a better setup for the uk. Also how many turns out on the fixture screw would it be if I changed to a prefered setup.
Many thanks
Darren
It'll depend on a lot of other things as well such as altitude and temperature. You should be able to get the info if you email Lapkins for a general set up (jets). You can fine tune it then with the needle and mixture screw.
  • 2 weeks later...
Well Billy, according to Jeremy Clarkson we're fatter in the US (he's right of course) so we probably need to run a bit richer. :D
I'm assuming this is a 250/270? If so a 27.5 pilot runs cleaner on the bottom and gives a crisper transition to the midrange but will also accentuate any lean pinging you get from low octane fuel.
