darrenb Posted August 9, 2012 Report Share Posted August 9, 2012 Hi does anyone know the size of the big end bearings or bearing code? I usually get this info from the parts diagram on Haven but it's not showing a separate bearing and trials and tribs are just offering a full rod kit! Ta Darren Quote Link to comment Share on other sites More sharing options...
goudrons Posted August 9, 2012 Report Share Posted August 9, 2012 Hmm, why would you just want to change the big end bearing on it's own? The big end pin also wears as the bearing rubs against it, as does the faces inside either end of the conrod. Might be false economy to just replace the bearing. If you do just need the bearing, check the bearing cage for numbers (usually stamped/etched on one the end of the cage) With this bearing code number, you should be able to source one from a bearing supplier. Quote Link to comment Share on other sites More sharing options...
