txt270 Posted August 11, 2012 Report Share Posted August 11, 2012 (edited) Hi guys, need some advice, bike is a 1999 txt270 and my "L" cylinder hose burst when i was out the other day.. had a look to find a set online and for that model of bike it proves impossible.. my question is will a hose set for a 1999 txt321 gas gas fit? i have found this set online and wondered if the L hose will fit mine.. .. same year bike just mines is a 270 instead of a 321.. http://racebikebitz....it#!prettyPhoto[gallery]/0/ Doing a restoration on the bike and was the day after i fitted a new s3 piston kit in the bike that this happened Thanks guys Edited August 11, 2012 by txt270 Quote Link to comment Share on other sites More sharing options...
jse Posted August 11, 2012 Report Share Posted August 11, 2012 Hi guys, need some advice, bike is a 1999 txt270 and my "L" cylinder hose burst when i was out the other day.. had a look to find a set online and for that model of bike it proves impossible.. my question is will a hose set for a 1999 txt321 gas gas fit? i have found this set online and wondered if the L hose will fit mine.. .. same year bike just mines is a 270 instead of a 321.. http://racebikebitz....it#!prettyPhoto[gallery]/0/ Doing a restoration on the bike and was the day after i fitted a new s3 piston kit in the bike that this happened Thanks guys I looked at the 99' TXT parts book and it lists the #L200007 curved hose for both the 270 and 321 so I'm guessing they are the same. Jon Quote Link to comment Share on other sites More sharing options...
thats_a_five Posted August 12, 2012 Report Share Posted August 12, 2012 I took my old hose to an auto parts store and found a preformed heater hose with the same ID and bend. It had long straight sections on both sides of the bend so I cut the middle to the length I needed for the bend then used the long straight sections to replace the other straight hoses on the bike! I think it cost me about $12 for a complete set of new hoses! Quote Link to comment Share on other sites More sharing options...
