mickmc Posted August 13, 2012 Report Share Posted August 13, 2012 hi could anyone give me any advice of exactly how to refit the linkage bearings (dogbones) on a gas gas 125 2011 do you use normal or waterproof grease any advice/help appreciated Mick Quote Link to comment Share on other sites More sharing options...
laser1 Posted August 13, 2012 Report Share Posted August 13, 2012 This should get you started. http://www.youtube.com/watch?v=OhoF-tJVolU&feature=player_embedded Quote Link to comment Share on other sites More sharing options...
craigh88 Posted August 13, 2012 Report Share Posted August 13, 2012 I used a waterproof grease on the roller bearings, the rollers themselves and the outside of the sleeve. But then I use an anti sieze compound (copper slip) on the bolts and the outside of the bearing (the part that contacts the actual dog bone). The bolts are a nightmare if the sieze to the sleeve inside the bearing, and a smear inside the dog bone will help when replacing bearings next time. Quote Link to comment Share on other sites More sharing options...
