smallboy Posted August 18, 2012 Report Share Posted August 18, 2012 Hi all Just removed the radiator/ coil etc,refitted it, bike starts and runs ok ,how can I test if the fan cuts in , would prefer to confirm working before I ride. Cheers Quote Link to comment Share on other sites More sharing options...
smallboy Posted August 18, 2012 Author Report Share Posted August 18, 2012 The bike is a GAS GAS Pro 250 2011 Quote Link to comment Share on other sites More sharing options...
laser1 Posted August 19, 2012 Report Share Posted August 19, 2012 (edited) Short the terminals of the thermo switch together. Fan should come on right away with bike running. If you want to verify the functionality of the Thermo Switch. You need to remove it from the bike and test it in hot boiling water. Should be open when cold and closed (shorted) when hot. FWIW: In normal operation, when the switch senses hot coolant, it closes (short across leads)and connects AC power to the 12v DC converter/rectifier that in turn powers the 12Vdc fan. Edited August 19, 2012 by laser1 Quote Link to comment Share on other sites More sharing options...
gjbiker Posted August 19, 2012 Report Share Posted August 19, 2012 On 8/19/2012 at 12:22 AM, laser1 said: If you want to verify the functionality of the Thermo Switch. You need to remove it from the bike and test it in hot boiling water. Should be open when cold and closed (shorted) when hot. Just had one that tested perfectly well using this method but still allowed the bike to overheat - new thermostat worked perfectly so I can only assume the dodgy thermo had self adjusted its parameters to a higher temp? In other words this test only works if you know the temperature that it should close at and you use a thermometer to verify this? GJ Quote Link to comment Share on other sites More sharing options...
thats_a_five Posted August 19, 2012 Report Share Posted August 19, 2012 Yes, thermoswitches can change their cut on temp over time. Particulalry if they get overheated. When I test I hook up the wires to a meter, put in a pan of water witha cooking thermmeter and bring the water to a boil. You can tell very easily if it is turning on a a good temp. Quote Link to comment Share on other sites More sharing options...
