jtrials31 Posted August 29, 2012 Report Share Posted August 29, 2012 Anyone know of a way to get the rear fenders back up higher like they were new? Mine has bent down a little like they always do. Is the only solution to buy a new one? Anyone know about how much a new one is? (USD) Quote Link to comment Share on other sites More sharing options...
paulmac Posted August 29, 2012 Report Share Posted August 29, 2012 The 'works' trick is a small block of wood to wedge between the fender and the rear tyre to get the fender where you want it then... Borrow the other half's hair dryer and gently play it on the gaurd - but do be carfull or you could end up with a F1 style airfoil... Paul Mac Quote Link to comment Share on other sites More sharing options...
jtrials31 Posted August 30, 2012 Author Report Share Posted August 30, 2012 Thanks, I may see what I can do to give that a try. Would it work if I put the block under there and let it sit for a while? Not sure if I want to chance messing it up completely. Quote Link to comment Share on other sites More sharing options...
paulmac Posted September 2, 2012 Report Share Posted September 2, 2012 It might but I think you'll need the heat to 're train' the plastic Paul Mac Quote Link to comment Share on other sites More sharing options...
