keithns Posted September 1, 2012 Report Share Posted September 1, 2012 DOES ANYONE KNOW WHAT THE VOLTAGE FROM THE REGULATOR SHOULD BE, REASON BEING I HAVE JUST SMOKED THE SOLENOID ON THE FUEL TAP AND DO NOT WANT TO FIT A NEW ONE AT 85+QUID IF ITS GOING TO GET SMOKED TOO. I HAVE CHECKED THE VOLTAGE AT THE SOLENOID AND ITS FAIRLY STEADY AT 14.25ISH VOLTS IS THIS CORRECT ?. Quote Link to comment Share on other sites More sharing options...
zerorev3rev4 Posted September 1, 2012 Report Share Posted September 1, 2012 voltage looks good ,personally id bin the electric tap and replace with a banjo and run fuel line through a inline tap that way you know when its off and on and cant go wrong Quote Link to comment Share on other sites More sharing options...
