Master Cylinder Covers
shercoben12
Nope,
as long as there is fluid in the master cylinders and not sucking air into the lines you should be ok just topping off the fluid and putting the covers on.
Are you having problems with the front brake/clutch currently? or have you just noticed fluid level in the window is low?
