Help Please 2011 Cabestany 300
2011 cab 300
Hi was wondering If anyone can help me. I am needing to change my kickstart shaft seal and I'm not sure how to do it. I started to take off side casing and my coolant started to seap out so I quickly put bolts back in as I'm not sure if this should happen. If there's anyone out there kind enough to maybe reply with a step by step process. Thanks, I have the kickstart seal and casing gasket.
Hi all you need to do is take the kick start of and pick out the old seal witch is behind the kick start with a small screw driver or pick and the insert the new seal with a suitable size socket. Also i would advise changing the gearbox oil as the water could of got into there. hope this helps
