hendrik Posted September 8, 2012 Report Share Posted September 8, 2012 (edited) I have a problem with my B40 fork ( heavy weight ) When I put the Fork shaft into the Bottom tube the lower bush stops at about 2 inches, normaly ( at Spanish and japanese forks) I can move the shaft down to the ground of the tube..... What should I do ? Reducing the diameter of the lower bush a little bit ? I change no parts except the seals on the fork and before disassembling everything works fine...... Edited September 8, 2012 by hendrik Quote Link to comment Share on other sites More sharing options...
hendrik Posted September 8, 2012 Author Report Share Posted September 8, 2012 Forks completed, wheel mounted.... next time i will take only the engine and put the rest in the dustbin..... Quote Link to comment Share on other sites More sharing options...
