haighy Posted September 17, 2012 Report Share Posted September 17, 2012 I have got a pair of trials boots and the leather is like new and well looked after but the soles are worn,can you get new soles for them?does any body know who re soles them? Quote Link to comment Share on other sites More sharing options...
tazz229 Posted September 18, 2012 Report Share Posted September 18, 2012 Any good reputable "shoe fixit shop" kinda thing I would imagine. The part around the toes on mine are starting to peel away so I'll be taking mine to someone oon to have them re-glued.. Quote Link to comment Share on other sites More sharing options...
lowbrow Posted September 18, 2012 Report Share Posted September 18, 2012 I had the soles on a pair of Gaernes replaced by a local cobbler; he told me mine were the first and last pair he'd ever tackle! Apparently it took ages to grind the old soles off mainly because the process filled the shop with so much smoke the fire alarm kept going off. He did do a good job, but the new soles could've done with some little screws or something else to secure them at the front edge because they started peeling off and would never stick back down for long. Quote Link to comment Share on other sites More sharing options...
overdale Posted September 18, 2012 Report Share Posted September 18, 2012 If you have Gaerne boots, MRS can supply new soles, maybe other importers also can for their boots. A good old fashioned shoe repairer should be able to do the job, and if the surface is prepared correctly, clean and dry, good quality contact adhesive should give a secure sole. Quote Link to comment Share on other sites More sharing options...
laser1 Posted September 18, 2012 Report Share Posted September 18, 2012 Your Gaerne soles must have been on there alot better than mine. My cobbler ripped mine off clean with a pair of vise grips. Both boots! No grinding involved. He was not impressed with there overall construction and called them cheap! I always liked them other than the soles delaminating too easy. It was only $15 to repair (I supplied the replacement soles) so I can live with replacing them on a yearly basis if needed. I had the soles on a pair of Gaernes replaced by a local cobbler; he told me mine were the first and last pair he'd ever tackle! Apparently it took ages to grind the old soles off mainly because the process filled the shop with so much smoke the fire alarm kept going off. He did do a good job, but the new soles could've done with some little screws or something else to secure them at the front edge because they started peeling off and would never stick back down for long. Quote Link to comment Share on other sites More sharing options...
haighy Posted September 20, 2012 Author Report Share Posted September 20, 2012 Cheers lads i will try and get some from mrs and let you know how i get on Quote Link to comment Share on other sites More sharing options...
