mx_phreek Posted September 19, 2012 Report Share Posted September 19, 2012 Will try this again after a little brain fart posting in wrong section.. My friend has just got this, we are going to give it the quick once over and service. Is there tips or trick for this bike to look for our any mods that need doing. I can only find the 09 manual online, don't think there should be much difference in it? On valve clearances, 15" ex and 10"in and a 10-50 weight engine oil? Will give oil filter a clean also. Oh, how do you know if you have correct cam chain tension, is there a knack to doing it right. Sorry for all the questions... Thanks Gavin. Quote Link to comment Share on other sites More sharing options...
copemech Posted September 20, 2012 Report Share Posted September 20, 2012 (edited) The guide on the Sherco site states 0.10mm intake clearance and 0.15mm exhaust, (Note not in .001 in. increments) Very close clearances. No idea about the tensioner. I would presume it is a spring loaded device, possibly with a lock down bolt? Edited September 20, 2012 by copemech Quote Link to comment Share on other sites More sharing options...
mx_phreek Posted September 20, 2012 Author Report Share Posted September 20, 2012 Anyone know recommended jetting, there is a slight bog, hesitation right of idle, checked needle clip position, it on top clip? thinking of dropping to middle and trying that. Quote Link to comment Share on other sites More sharing options...
copemech Posted September 21, 2012 Report Share Posted September 21, 2012 If you are in UK, try Splatshop! Quote Link to comment Share on other sites More sharing options...
