colin13846 Posted September 24, 2012 Report Share Posted September 24, 2012 (edited) As per title just bought a 2006 Scorpa. I am looking forward to riding it but first want to go over it regarding maintenance etc. Any specific Scorpa tips regarding preventative maintenance and any essential tweeks etc? Thanks PS Regarding the age it was V5 registerd Nov 2006 but the 12th charactor on the frame is a 7 which I am led to believe makes it a 2007 model I think?? Edited September 24, 2012 by colin13846 Quote Link to comment Share on other sites More sharing options...
pete_scorpa3 Posted September 24, 2012 Report Share Posted September 24, 2012 Take a look below the exhaust centre box and see if the corner of the moulding that sticks up from the top of the gearbox has been ground off. If not, it tends to stick into the centre box which in turn splits. If the moulding is still square (rectangular) then grind the corner off. Not a big job if you do it when you have the carb off for cleaning. Quote Link to comment Share on other sites More sharing options...
paulmac Posted September 25, 2012 Report Share Posted September 25, 2012 Hey Colin 13846 - Here's a couple of tips that will help The SY motor hates a dirty carb - so first job is to get it off and give it a damn good clean - blow out the jets and check the float height. The air filter and carb are not the easiest to get at first time around - although you quickly learn to put it on a stand/crate, take off the rear guard, support the rear wheel, remove the rear shock top bolt and swing the shock out of the way - sounds tricky but it's dead easy second time around. Clean the air filter well - better still replace it with a new one - some argue don't oil the filter - I always oiled mine with a frugal spray of PJ1. Then clean it after each ride to save you stripping the carb down too frequently. The original oil drain plug is made of 'toffee' so if your changing the oil ( 400mls of Light Gear Oil is good) which should be next... change the drain plug too. Most other stuff is bullet proof - ride and enjoy... Paul Mac Quote Link to comment Share on other sites More sharing options...
ducati996 Posted September 26, 2012 Report Share Posted September 26, 2012 2006 scorpa has silver frame 2007 has black frame. Quote Link to comment Share on other sites More sharing options...
colin13846 Posted October 7, 2012 Author Report Share Posted October 7, 2012 Thanks for the advice and posts to my original post. Getting to know the bike a little better now and completed the following jobs New gear box oil - Motul 5100 10w 40 Drain plug seems new and substantial New Iridien plug New front wheel bearings New front brake pads Drained old fuel and new added Removed middle box and ground sharp casing corner off Drive chain removed, clened and gresed Clutch and brake lever end play adjusted Air filter cleaned and lightly oiled but I am going to fit a new one as soon as I can get one. . Phew, have I missed antything? Bike certainly starts easily. Quote Link to comment Share on other sites More sharing options...
