matt h Posted May 9, 2005 Report Share Posted May 9, 2005 Hi from Australia. Great website! How many Tlr250s were made and where in the world did they end up? There are some in Aus & NZ. My engine no.ME07E5000662. Honda Aus are no help. 1 Quote Link to comment Share on other sites More sharing options...
slapshot 3 Posted May 9, 2005 Report Share Posted May 9, 2005 Hi Matt, I know there's one in various pieces in Stonehaven just now. I don';t know how many were made but there seems to be a hell of a lot of themcoming out of the woodwork at the moment. dy Quote Link to comment Share on other sites More sharing options...
pete Posted May 9, 2005 Report Share Posted May 9, 2005 Havn't seen many around, but there is one that rides in NHMC has just been rebuilt over the period of a few years I think. I used to have a TLM 50, the baby brother. Would give anything to have a 250. Sherco,car, everything! Sorry, this is more a post of admiration than help i'm afraid. Just want to drool a little bit more. . . Quote Link to comment Share on other sites More sharing options...
panomphaean Posted May 9, 2005 Report Share Posted May 9, 2005 But which TLR:) The TLR250R - G was introduced in 1986 as a trail tourer for the Japanese market. The 2 previous models were the TLR200 and the TLR250 - F. I believe there is also a later H model in 1987. The specs for the TLR250R - G are as follows: Length 2030mm Width 820mm Height 1110mm Wheel base 1335mm Weight 93kg Air cooled 4 stroke single cylinder 244cc Bore and stroke 72.0 x 60.0mm Compression ratio 8.5 Max power 14.0 ps/5500rpm Max torque 2.00 kg - m/2500rpm Kick start 6 speed Front telescopic suspension Rear Pro - link suspension Front tyre 2.75 x 21 Rear tyre 4.00 x 18 TLR250R - G (MD18) Service Spec. Valve timing Intake Open TDC 0 degree at 1mm lift Close ABDC 30 degree at 1mm lift Exhaust Open BBDC 35 degree at 1mm lift Close TDC 0 degree at 1mm lift Compression ratio 8.5 Compression 12.0 kg/cm2 at 400 rpm Max power 14 PS at 5500 rpm Max torque 2.0 kg Quote Link to comment Share on other sites More sharing options...
james111089 Posted May 9, 2005 Report Share Posted May 9, 2005 Nice bike but the acerbis handguards dont look to good on it James Quote Link to comment Share on other sites More sharing options...
panomphaean Posted May 9, 2005 Report Share Posted May 9, 2005 james111089 said: Nice bike but the acerbis handguards dont look to good on it James Ta. Then obviously u don't ride hard enough to warrant the use of;) Quote Link to comment Share on other sites More sharing options...
panomphaean Posted May 9, 2005 Report Share Posted May 9, 2005 HondaRS said: TLR250R is a Japanese market trail bike, and not I think what the op was interested in.The TLR250 was a purpose built twin-shock trials machine, which was based on the earlier TLR200, having many parts in common with the smaller bike. As the TLR250 was introduced very close to the time the TY250 Yamaha appeared I wouldnt imagine the production run was very long, as around the time the Yam came out, all twin-shock machines basically became obsolete overnight! Thanks for the history lesson Grannie:) Aye...Ridden RTL's, Yam's etc. Only had 47 bikes but hey..still it is a TLR and the Aussie didn't spec his use. The TLR R makes a good LDT bike. Bit of work and it would be fine for closed to club fun. Quote Link to comment Share on other sites More sharing options...
matt h Posted May 9, 2005 Author Report Share Posted May 9, 2005 Bike is a 1985 Tlr250f, used for trail riding with a view of competing in post classic trials in the near future. Last time I rode competition was in 1983 on a tl250 k1. Quote Link to comment Share on other sites More sharing options...
matt h Posted May 10, 2005 Author Report Share Posted May 10, 2005 It has a 11/40 sprocket setup which I had felt was a bit high. Will try to locate a 9. None of these bikes were sold in the US apparently. I remember when those Yamahas came out and nailed everything, so that adds up. Quote Link to comment Share on other sites More sharing options...
g4321 Posted May 10, 2005 Report Share Posted May 10, 2005 (edited) Quote When you fit the 9T gearbox sprocket, you will need to secure it with a circlip, and get hold of a spacing washer to take up the gap left by the std Honda mounting plate. To save confusion HondaRS picked me up on this when I mentioned the same for a TLR200 You should find that the TLR250 has a circlip holding the front sprocket in place as standard, its the TLR200 which uses a mounting plate. The only drawbacks of a 9tooth sprocket is increased chain wear & low top speed. If those are original Honda mudguards I would suggest that you take them off and store them carefully then buy a cheap universal set to use on the bike. Original Honda guards are like hens teeth and are now fetching silly money so replace the original ones rather than snapthem if you intend to trial the bike. Well done Panomphaean in posting the details of the other TLR model - its the sort of information that will be usefull to many people. Gordon Edited May 10, 2005 by g4321 1 Quote Link to comment Share on other sites More sharing options...
matt h Posted May 11, 2005 Author Report Share Posted May 11, 2005 Any pictures of the RS250TA? Quote Link to comment Share on other sites More sharing options...
lastplacebrad Posted May 11, 2005 Report Share Posted May 11, 2005 PANOMPHAEAN,,That bike of yours looks familiar , have you ever transported it in an odd little french car , or ridden up a dam on an alp ! Quote Link to comment Share on other sites More sharing options...
miked Posted May 12, 2005 Report Share Posted May 12, 2005 this could be a the same bike except for the seat badges. Quote Link to comment Share on other sites More sharing options...
matt h Posted May 13, 2005 Author Report Share Posted May 13, 2005 Nice bike! Is the tank/seat one peice? Fuel tap & cap is different otherwise not much else. Some incredible bikes appearing! Quote Link to comment Share on other sites More sharing options...
panomphaean Posted November 4, 2005 Report Share Posted November 4, 2005 lastplacebrad said: PANOMPHAEAN,,That bike of yours looks familiar , have you ever transported it in an odd little french car , or ridden up a dam on an alp ! <{POST_SNAPBACK}> Err yes...who be that? http://john.rushworth.com/pics/TLR250R-G/ Quote Link to comment Share on other sites More sharing options...
