jms61uk Posted October 12, 2012 Report Share Posted October 12, 2012 (edited) Hi all. I have a set of forks and front wheel on my bike from a Montesa Cota, and I need to identify them so I can get hold of a brake cable. They are 35mm and had the word "MONTESA" cast into the bottom of the alloy slider - not the "M" logo seen on some forks, and I think they were from the early 1970's. Is there any way of working out the year and model, or are all the brake cables interchangeable. I got them on ebay a while ago for my pre 65 project bike, so I have very little info. Also, how much and what type of oil goes in each leg. I can add I picture once I've worked out how............ All help, hints, tips and info will be much apreciated, Thank. Jon Summerfield. Edited October 12, 2012 by jms61uk Quote Link to comment Share on other sites More sharing options...
jms61uk Posted October 12, 2012 Author Report Share Posted October 12, 2012 I hope this is the picture of the forks mentioned above, Quote Link to comment Share on other sites More sharing options...
chris_ Posted October 13, 2012 Report Share Posted October 13, 2012 They look like Cota 247 forks to me. These appear to be the later, mk 3 (1971) and onwards, which were then all the same up to 1980. Early Cota forks are thicker. The brake arm looks the same as the later 247s of mine, so I think this probably remained unchanged as well, after 1971. Quote Link to comment Share on other sites More sharing options...
jms61uk Posted October 15, 2012 Author Report Share Posted October 15, 2012 Thanks for the info, I've just sent off for a brake cable. Looking at pictures on the web I realise I don't have the bracket that mounts the cable to the mudguard stay, so I will have to fabricate something. Quote Link to comment Share on other sites More sharing options...
kombivan Posted December 11, 2012 Report Share Posted December 11, 2012 you need a fork slider with the two holes one for the brake drum stay and the one behind for thecable holder bracket. i had some made up by an engineering shop out of brass si it doesn't rust. Quote Link to comment Share on other sites More sharing options...
dr nosh Posted December 18, 2012 Report Share Posted December 18, 2012 jms61. I'm currently building a 1981 Cota 248 and am missing this part to hold the brake cable. I welded a s/s M6 nut to a s/s bolt long enough to locate and bolt through the mudguard stay. Weld the nut at right angles to the bolt thread. When cold, cut a slot in the nut to allow the cable to pass through. Screw the cable adjuster into the nut. Bob's your uncle. Quote Link to comment Share on other sites More sharing options...
