sando994 Posted October 13, 2012 Report Share Posted October 13, 2012 What's the best way to setup my suspension for my weight?? Any input is appreciated. Quote Link to comment Share on other sites More sharing options...
nzralphy Posted October 14, 2012 Report Share Posted October 14, 2012 Hi. Check the rear links and swing arm are greased. Change the fork oil oil for some fresh oil. Get your riding gear on. Get a friend to help. Stand on the bike and check how much sag you get. You need to set things with 1/3 sag when ready to ride. Check things a few times because there is some sticky ness. Try to be mm accurate. Trials bikes spring rate is very forgiving in how they are set up but if you are under 65kg or over 95kg there is a chance you may need different springs. Both ends will have rebound damping. Adjust damping to take all the fast/bouncy-feel rebound away. Slightly slower will give slightly more traction. Quote Link to comment Share on other sites More sharing options...
