sherco34 Posted October 28, 2012 Report Share Posted October 28, 2012 Hi Guys, Since fitting a stand to my sherco 08, the spring seems to rub on the tyre, does anyone else have this problem? Also how could I fix it? Quote Link to comment Share on other sites More sharing options...
digger144 Posted October 28, 2012 Report Share Posted October 28, 2012 a cable tie on top end of spring around stand, a simple fix Quote Link to comment Share on other sites More sharing options...
copemech Posted October 29, 2012 Report Share Posted October 29, 2012 You may also tweak your snailcams a bit to insure the tire is centered in the swingarm. Quote Link to comment Share on other sites More sharing options...
sherco34 Posted October 30, 2012 Author Report Share Posted October 30, 2012 hi, yeah the wheel is centre I will try the cable tie Quote Link to comment Share on other sites More sharing options...
charlie chitlins Posted October 30, 2012 Report Share Posted October 30, 2012 Don't trust the marks on the snails. Make sure the chain is centered on the sprocket teeth. Quote Link to comment Share on other sites More sharing options...
