theshercorider Posted October 31, 2012 Report Share Posted October 31, 2012 Hey folks, Is it possible just to remove the map switch? Mine is smashed to bits and I prefer a clean bar look. I never really notice a difference and always run it on the softer map 2. Is there any way to take it off and manually make a change, I.e. if its a dry summer day if I wanted to with some tinkering I could change it and run it on map one for the day? Cheers Duncan Quote Link to comment Share on other sites More sharing options...
baldilocks Posted October 31, 2012 Report Share Posted October 31, 2012 yes all the switch is doing is making or breaking the circuit. You could achieve the same joining the two wires. Quote Link to comment Share on other sites More sharing options...
theshercorider Posted October 31, 2012 Author Report Share Posted October 31, 2012 Awesome, do you know which would give what map? Quote Link to comment Share on other sites More sharing options...
baldilocks Posted November 1, 2012 Report Share Posted November 1, 2012 soft map is circuit broken / switch removed. I took it off my 2012 as it makes little difference at low rpm. Chris at splatshop put a diagram on here a while back Quote Link to comment Share on other sites More sharing options...
