Kickstart Problems
cursed
Cheers Steve, will give that a go! Unfortunately I'm busy for the next Waltham Chase trial so wont be there, but the following one after that I should be able to make!
Hows the Sherco compared to the gasser?
Glad you have got it sorted, Bud.
I fancied a change from the gasser as i run out of things to tune on it and need an excuse to spend hours in the garage again. Luckily It's gone to a local guy in the south so I will still see it about, hopefully the right way up as it is an animal!
I have an ex factory sherco 300 2011, It's softer of the bottom but is very strong like the gasser right through the revs.
The most difference is the suspension, Better than the gasser, A Bit More Grip & the rear mounted fuel tank makes it very well balanced front to back, It endo's better and rides better on the back wheel.
I do love gassers still but the sherco was offered to me very cheap. I will probably get another when I'm bored with the sherco.
You will have to have a go when your'e next at a trial.
