spinningplates Posted November 4, 2012 Report Share Posted November 4, 2012 Just about to replace sprockets. what would be the best sprocket sizes front and back for genral trials sections. Many thanks. Quote Link to comment Share on other sites More sharing options...
woody Posted November 4, 2012 Report Share Posted November 4, 2012 Rear sprockets come in two sizes, 46 which was fitted to MK1 and 42 which was fitted to MK2 onwards. MK1 MAR is listed as having 46 / 12 but I'm pretty sure that would be quite high. I've never used a 12 tooth front sprocket. I always used to run 42 / 10 on my MK2 as I prefer low gearing using the smaller rear sprocket but you can have problems with the chain riding over the boss on a 10 tooth sprocket, so 11 is better. 42 / 11 gives higher but perfectly useable gearing in sections and you can use bottom for virtually everything with that. 46 / 11 is not far off the 42 / 10 combination for a lower option. If you don't mind the bigger of the rear sprockets, you could go for 46 / 11 as a lower option. Ultimately it's personal choice, but either of 42 / 11 or 46 / 11 will work ok. 1 Quote Link to comment Share on other sites More sharing options...
spinningplates Posted November 5, 2012 Author Report Share Posted November 5, 2012 Thank you Woody very comprensive answer. Its a mk1 so have gone for 46 / 11. fingers crossed should be the last thing I put on the the bike which was meant to be a cheap rebuilt renovation project. What was I thinking ? Quote Link to comment Share on other sites More sharing options...
woody Posted November 5, 2012 Report Share Posted November 5, 2012 fingers crossed should be the last thing I put on the the bike which was meant to be a cheap rebuilt renovation project. What was I thinking ? HaHa - I know what you mean - if ever you find the secret to one of those, let me know... Quote Link to comment Share on other sites More sharing options...
