Sprockets?
strong_lyk_bull
Hope this is a question worth an answer,
How much does the number of teeth on a sprocket matter? When replacing it do you have to replace for the exact same number of teeth or are you open to change it so it has a different effect?
Asking as i had a look about and could not really find the answer i was looking for?
This time next year i shalt not be a NOOB
If you like the gearing as it is, ie 1st isnt to high or to low, 2nd likewise - go for the same number of teeth back and front.
1 tooth on the front will make a big differance, 1 on the back, very little.
What are you trying to achieve ? Someone will know the best compromise.
I suggest if you need to change 1 sprocket that you bite the bullet and change both sprockets and the chain, also look at the chain tensioner block and swing arm rubbing blocks. that way they all wear together.
