Help Reaplacing Rear Spring
bert2365
Wind off the peload adjuster & you should get enough space to remove the retainer at the top of the shaft when you slide the rubber bumpstop down, the spring slides off easily.
Some shocks can be done by unscrewing the preload rings & removing them over the shock body
  • 2 weeks later...
