ivanski Posted November 11, 2012 Report Share Posted November 11, 2012 First off. Hi all, newbie's first post, Advice needed, been looking at y2k 290 really clean bike, problem is lean the bike over to the right in neutral and roll it forward and the gearbox locks up, stand the bike up roll back a bit and it frees off, motor has been apart, runs fine but whines in gear under load, any ideas/advice as to what problem could be? Quote Link to comment Share on other sites More sharing options...
feetupfun Posted November 12, 2012 Report Share Posted November 12, 2012 does it really lock up the gearbox, or is it just dropping into gear? Quote Link to comment Share on other sites More sharing options...
tony27 Posted November 12, 2012 Report Share Posted November 12, 2012 I believe I know the answer to this as I had the same problem after doing a rebuild a few years ago on mine, 1 of the washers that fits on the output shaft at the clutch end is on the wrong side of the crankcase. Can't remember if it will have been placed behind the idler gear for the kickstart instead of on the shaft before asssembly into the cases or the other way around. Basically what ends up happening is the gears don't sit in full alignment & when you lean the bike over 1 does try to engage with it's neighbour I'll see if I can find the thread about when I had the problem & post it in here Quote Link to comment Share on other sites More sharing options...
ivanski Posted November 12, 2012 Author Report Share Posted November 12, 2012 Hi thanks for replies, just had a chance to strip out the clutch and remove the basket to get a better idea of whats going on in there, taken out the selector shaft and tried to select gears by rotating the drum manually, and yes Feetupfun you're spot on,with the drum in the neutral position it is dropping into gear. Quote Link to comment Share on other sites More sharing options...
chuckindenver Posted November 12, 2012 Report Share Posted November 12, 2012 im parting a Sherco out right now, if you need anything, have a pretty much complete trans, minus the shifter shaft..{it broke} Quote Link to comment Share on other sites More sharing options...
zippy Posted November 12, 2012 Report Share Posted November 12, 2012 im parting a Sherco out right now, if you need anything, have a pretty much complete trans, minus the shifter shaft..{it broke} I have broken that shaft also on a Sherco I just sold......twice. apparently those shifter shafts don't like being used as a foot peg on a drop off. (Disclaimer: of course I fixed it each time and sold the bike in working condition) ivanski, This may help http://www.vmtc.at/Technik/Sherco/sparebook_07.pdf Pages 45 and 47 show exploded view of transmission gears, may help with locations of all the washers and such if it is something out of place. Quote Link to comment Share on other sites More sharing options...
chuckindenver Posted November 13, 2012 Report Share Posted November 13, 2012 i picked this bike up pretty cheap, was planning on rebuilding it, but learned..never buy an ex pros bike, they see hard use. Quote Link to comment Share on other sites More sharing options...
ivanski Posted November 13, 2012 Author Report Share Posted November 13, 2012 Think i've sorted this, split the cases today and, found a thrust washer the wrong side of one of the gears, gaskets should be here tomorrow so back together and fingers crossed out to play at the weekend. Quote Link to comment Share on other sites More sharing options...
copemech Posted November 16, 2012 Report Share Posted November 16, 2012 Think i've sorted this, split the cases today and, found a thrust washer the wrong side of one of the gears, gaskets should be here tomorrow so back together and fingers crossed out to play at the weekend. Thank you for your report. Although self induced, at least it was not by you! Quote Link to comment Share on other sites More sharing options...
copemech Posted November 16, 2012 Report Share Posted November 16, 2012 i picked this bike up pretty cheap, was planning on rebuilding it, but learned..never buy an ex pros bike, they see hard use. Chuck, I have a saying! There is nothing another $500 won't fix! Quote Link to comment Share on other sites More sharing options...
