old trials fanatic Posted November 16, 2012 Report Share Posted November 16, 2012 Anybody know if you can remove the clutch operating shaft without stripping the engine? Just asking cos i want to extend the arm on the top to make the clutch operation a bit lighter and dont fancy welding with it in situ. Thanks Quote Link to comment Share on other sites More sharing options...
baldilocks Posted November 16, 2012 Report Share Posted November 16, 2012 just rotate the shaft back / out and pull it up. Quote Link to comment Share on other sites More sharing options...
old trials fanatic Posted November 16, 2012 Author Report Share Posted November 16, 2012 just rotate the shaft back / out and pull it up. Thanks thats just what i was looking for Quote Link to comment Share on other sites More sharing options...
kevin j Posted November 17, 2012 Report Share Posted November 17, 2012 can you find any of the bolt on clutch extenders any more? Quote Link to comment Share on other sites More sharing options...
old trials fanatic Posted November 17, 2012 Author Report Share Posted November 17, 2012 can you find any of the bolt on clutch extenders any more? Havent seen any for ages thats why i'm thinking of welding. Quote Link to comment Share on other sites More sharing options...
baldilocks Posted November 17, 2012 Report Share Posted November 17, 2012 OTF i'd just oil the cable and it should be light enough. When you extend the clutch arm you reduce the amount the shaft separating the plates travels, often to get the bite point correct you end up with the clutch slipping in the higher gears. Why not just slide the lever down the bar a bit if its still to heavy ? Quote Link to comment Share on other sites More sharing options...
old trials fanatic Posted November 17, 2012 Author Report Share Posted November 17, 2012 OTF i'd just oil the cable and it should be light enough. When you extend the clutch arm you reduce the amount the shaft separating the plates travels, often to get the bite point correct you end up with the clutch slipping in the higher gears. Why not just slide the lever down the bar a bit if its still to heavy ? Fair points but i also dont find the clutch progressive enough when compared to my James and Ossa and am hoping to get the action more like the James, which has a very long clutch arm by comparison, or at least the OSSA which has also had it's clutch arm lengthened. The TY is too much like an on off switch for my liking as i like to be able to feather the clutch to help gain grip and am finding the TY too sharp and would like to lengthen the bite point. Just personal preference really. I do have a couple of spare arms anyway so no prob if it doesnt work. Remember it worked fine on my old TY in the 80's which after all is what i'm trying to recreate. Dont ever remember the old bike slipping and that had a 270 motor by Mick.Thanks for the advice though Quote Link to comment Share on other sites More sharing options...
