Cutting Out
andybetarev3
just a few questions.
did you have to remove the water pump, or drain the coolant?
Did you have to remove the fuel tank to top up coolant.
Maybe you have dislodged a wire,or got coolant into electrics.
Maybe you trapped the fuel line when you put tank back on.
Did you start the bike with the tank off? Maybe got dirt in the fuel line or in to the carb.
Just a few Ideas!
when things like this happen after you have been working on the bike, its usually human error and not just coincidence!
TLTEL
My bet is that he pulled the throttle cable out of the top of the carb. And it caught just around the lip of the adjuster that it must fit INTO, which is now holding the carb open by as much as 1/4th throttle possibly..
ANYTIME YOU work on a bike, before you start it, you GOT to be able to hear the carb's SLIDE hit bottom, it makes a distinct click when it hits the idle screw.
Edited by sting32
