betatest Posted May 12, 2005 Report Share Posted May 12, 2005 Just bought an 01 beta 200, nice bike, but the fan seems to be hitting the shroud, and hence is not spinning when I run the motor hot.. Not sure if it was damaged / moved in transit, or if it has been like this for a while. I'll pull it all apart tommorrow & check it out., but just wondering if there is a dismantalling procedure on the web somewhere? Also can anyone can suggest tests for fan, thermo switch etc. are they 12v devices or 5v? Is there a common cause of the fan hitting the shroud? TIA for any info. Quote Link to comment Share on other sites More sharing options...
ricksta Posted May 12, 2005 Report Share Posted May 12, 2005 (edited) i do know you can tets your fan off a car battery as i have done this many of times. sorry i cant help you with anything else Edited May 12, 2005 by Ricksta Quote Link to comment Share on other sites More sharing options...
betatest Posted May 12, 2005 Author Report Share Posted May 12, 2005 i do know you can tets your fan off a car battery as i have done this many of times. sorry i cant help you with anything else Thanks for that, it helps, as I wasn't sure it it was a 5v, 6v, or 12v system. I'll pull it all apart today & try & figure out the rubbing. Quote Link to comment Share on other sites More sharing options...
betatest Posted May 13, 2005 Author Report Share Posted May 13, 2005 i do know you can tets your fan off a car battery as i have done this many of times. sorry i cant help you with anything else Thanks for that, it helps, as I wasn't sure it it was a 5v, 6v, or 12v system. I'll pull it all apart today & try & figure out the rubbing. In the hope it will help someone else....I found the problem. The wiring connector had moved / fallen down and was pressing on the fan shroud which caused it to rub to fan blade in testing I also noted that 2001 beta fan takes a long time to com on, and then only breifly. Might be different on a really hot day :-) Quote Link to comment Share on other sites More sharing options...
