How To Know When The Tyre Is Over?
trialholic
Hey, what´s up?
I use a Michelin trial compettion fron tyre with still 1/5" (5mm) knobbles, I´m not sure if is just paranoia but I have the "feeling" that I don´t have too much grip.
I set the pressure at 6.5 psi
How do you know when a tyre is over and need to be replaced? what´s the limit?
I ride mostly over hard terrain, wet rocks with lots of stones, no mud. Would do you suggest me to keep with Michelin or better try Dunlop?
Cheers
5MM Knobbles!!!!!!!!!!
it was knackered about 6 months ago.
4 psi is a starting pressure. Bit less for mud and perhaps a bit more when dry and sunny on rocks.
If you only have 5 mm of tread then it worn out. I rarely take more than a couple of mm off the height of the tread. Its the squareness of the tread that grips. Rub your hand over the tread of a new tyre and a used tyre to feel the difference.
