kombivan Posted March 8, 2014 Author Report Share Posted March 8, 2014 yes you can fit main bearings without splitting the case very good idea. Quote Link to comment Share on other sites More sharing options...
bigshineybike Posted March 10, 2014 Report Share Posted March 10, 2014 Possible yes, but It is unlikely to be practical. If you split the cases then the bearings will likely stay in the casing and you can easy press them out. they may stick to the crank then you can get a legged puller and easily pull them off maybe with a hot air gun to ease every thing. To do this without splitting the cases you will need a special blind bearing puller. You not be able to use much heat. Putting in the new bearings feels like it might be quite an aggressive operation and there is a careful shimming process you need to do. Previous owner of my bike lost all the shims, which isnt good for end float between the seal holders. there are a few shims in the gearbox, they are fairly critical to gearchanging. They are determined by thickness of the new gasket you use. don't mix them up, watch out for them falling as the halves come apart, they should stick in the oil and fall off ten minutes after you separate the cases. Quote Link to comment Share on other sites More sharing options...
kombivan Posted March 10, 2014 Author Report Share Posted March 10, 2014 I have a friend that replaced the main bearing in his 247 cota with out pulling down the engine I didn't watch him do it but he did it. This was however a main bearing that failed early in life so that might have made things easier. Quote Link to comment Share on other sites More sharing options...
kombivan Posted April 8, 2014 Author Report Share Posted April 8, 2014 Quote Link to comment Share on other sites More sharing options...
kombivan Posted April 8, 2014 Author Report Share Posted April 8, 2014 Box of new Goodies for my Monty Quote Link to comment Share on other sites More sharing options...
kombivan Posted April 8, 2014 Author Report Share Posted April 8, 2014 Reconditioned wheels new stainless spokes one gauge larger on the front by Wheel Works Fredrickton Australia. New wheel bearings and seals from http://www.inmotiontrials.com New rubber from Taree Motorcycles. Quote Link to comment Share on other sites More sharing options...
kombivan Posted April 8, 2014 Author Report Share Posted April 8, 2014 I am so glad my ancestors were shipped here on the First Fleet. Eat your hearts out! Quote Link to comment Share on other sites More sharing options...
kombivan Posted August 28, 2014 Author Report Share Posted August 28, 2014 Just noticed in the Montesa Forum that I am "HOT" lol. 1 Quote Link to comment Share on other sites More sharing options...
mjwilson Posted September 28, 2014 Report Share Posted September 28, 2014 Hi All, Ive just bought a 349 White Wonder basket case. I've got it stripped down in the main ready for blasting and painting. Does anyone have a manual that could be downloaded to help with the rebuild? Has anyone replaced the big end without purchasing a complete con-rod kit. The little end is in good condition and there seems to be no lateral movement in the big end. I'm just worried about rebuilding without replacing the bearing. Anyone any thoughts? Quote Link to comment Share on other sites More sharing options...
kombivan Posted September 28, 2014 Author Report Share Posted September 28, 2014 (edited) I have tried to attach a 349 manual to this post hope it worked. manualcota349-4.pdf Edited September 28, 2014 by kombivan Quote Link to comment Share on other sites More sharing options...
kombivan Posted September 28, 2014 Author Report Share Posted September 28, 2014 remember to coat all new machined parts with wd40 to prevent rust when storing. Quote Link to comment Share on other sites More sharing options...
mjwilson Posted September 30, 2014 Report Share Posted September 30, 2014 Hi Kombivan, the attachments here, I'll try and download. Thanks a lot. I take you point about spraying up,the bits!! Good advice. Regards. Quote Link to comment Share on other sites More sharing options...
kombivan Posted October 1, 2014 Author Report Share Posted October 1, 2014 WD40 displaces water so it doesn't trap water to your metal like oil & grease I have a 1985 push bike that is still like brand new because i coated with wd40 after each time i use it. Quote Link to comment Share on other sites More sharing options...
mjwilson Posted October 14, 2014 Report Share Posted October 14, 2014 Does anyone know the RAL number for Montesa Red? Frame and fork legs ready for powder coating. Quote Link to comment Share on other sites More sharing options...
