zippy Posted December 1, 2015 Report Share Posted December 1, 2015 Quote Link to comment Share on other sites More sharing options...
crazybond700 Posted December 2, 2015 Report Share Posted December 2, 2015 in the shock! THere is one other! Quote Link to comment Share on other sites More sharing options...
guys Posted December 2, 2015 Report Share Posted December 2, 2015 THere is one other! In your hands Quote Link to comment Share on other sites More sharing options...
crazybond700 Posted December 2, 2015 Report Share Posted December 2, 2015 Nooo (ok it took me more than half an hour too find too) Quote Link to comment Share on other sites More sharing options...
lineaway Posted December 2, 2015 Report Share Posted December 2, 2015 Still in the socket, sounds like me looking for something I just set down. Quote Link to comment Share on other sites More sharing options...
crazybond700 Posted December 2, 2015 Report Share Posted December 2, 2015 (edited) No, think well about where it normally should be! Putting it back in the frame or shock makes you need to take it back out again etc with putting it back together. So you put it in some other part... Edited December 2, 2015 by crazybond700 Quote Link to comment Share on other sites More sharing options...
lineaway Posted December 3, 2015 Report Share Posted December 3, 2015 (edited) The damn exhaust hole. Shheez. I have a air lift bike stand. That I have had about thirty years. I have a certain placement for most parts. If it`s not there, I`m lost! Edited December 3, 2015 by lineaway Quote Link to comment Share on other sites More sharing options...
crazybond700 Posted December 3, 2015 Report Share Posted December 3, 2015 The damn exhaust hole. Shheez. I have a air lift bike stand. That I have had about thirty years. I have a certain placement for most parts. If it`s not there, I`m lost! Haha, yes! Took me (too) too long Quote Link to comment Share on other sites More sharing options...
crazybond700 Posted December 6, 2015 Report Share Posted December 6, 2015 (edited) Had my first competition with the bike again and it all runs smooothly. Still some things on the list to do's though. (something with time and lack of it) Also yesterday added new sprockets chain and wheel bearings. Still to do: Weld and paint frame (and add guards) Put on new tanksticker and airbox side stickers Rehaul front suspension Edited December 9, 2015 by crazybond700 Quote Link to comment Share on other sites More sharing options...
zippy Posted February 6, 2016 Report Share Posted February 6, 2016 Well the Old BAGG (Bad Ass GasGas 2003 300 pro) had a slight rattle in the top end. I was thinking wrist pin bearing. This is her. She ain't exactly pretty but sure is fun to ride............... So tear off Top end and discover I need Piston, Rings, Wrist pin and Wrist pin bearing Quote Link to comment Share on other sites More sharing options...
zippy Posted February 6, 2016 Report Share Posted February 6, 2016 I discovered another problem when I drained the Gear oil................... a tooth stuck to the drain plug. (magnets, how do they work?) So pull Clutch cover off and investigate. ALL the gears under clutch cover are in great shape, they have all their teeth. I did find out I need a new Clutch Throw out bearing. 6 of the rollers are unaccounted for. My fear is they went into the gearbox and broke a tooth off the gear. I will find out when I split the cases. Quote Link to comment Share on other sites More sharing options...
zippy Posted February 7, 2016 Report Share Posted February 7, 2016 When I realized that I did not have the correct flywheel puller, I gave my good friend Biffsgasgas a call and met him for a . We chatted trials, cars and railroad ties. Then parted ways so that I could use the flywheel puller he had just loaned to me. After splitting the cases I found the gear that is in need of dental services. On initial inspection I cannot find any other damage inside the gear box. I will look at the rest of it closer upon disassemble to get the broken gear off the shaft. (that is not rust on crankshaft, just some icky oil residue) Quote Link to comment Share on other sites More sharing options...
guys Posted February 7, 2016 Report Share Posted February 7, 2016 Oh well, at least you'll know what to do on these cold winter days. Are you gonna do a complete rebuild now the cases are split? Quote Link to comment Share on other sites More sharing options...
crazybond700 Posted February 8, 2016 Report Share Posted February 8, 2016 (edited) New gear, put together, oil in it and ride! Altough its not really much work to put new bearings in her now she is open. (still old setup on the 2003) Edited February 8, 2016 by crazybond700 Quote Link to comment Share on other sites More sharing options...
zippy Posted February 8, 2016 Report Share Posted February 8, 2016 Oh well, at least you'll know what to do on these cold winter days. Are you gonna do a complete rebuild now the cases are split? Sad thing is that it has not been that cold here. Actually got up to 40F this past weekend, I wanted to go riding.. I am not doing a total rebuild but the bearings on the countershaft (? sprocket goes on) sound/feel a little crunchy, and the bushing with the O-rings under is worn, so I plan to replace those parts as well. Everything else looks good. I think I got lucky that there is not more damage. 1 Quote Link to comment Share on other sites More sharing options...
