shercoben12 Posted October 25, 2013 Report Share Posted October 25, 2013 on this very sad day im leaving you fellow gasser riders - just ordered a 2014 JTG 250 1 Quote Link to comment Share on other sites More sharing options...
mr neutron Posted October 25, 2013 Report Share Posted October 25, 2013 Sacrilege, Ben!!! But Congrats on the new Bike!!! Jimmie 1 Quote Link to comment Share on other sites More sharing options...
shipdamite Posted November 23, 2013 Author Report Share Posted November 23, 2013 cleaned the bike to get it dirty again at a trial tomorrow. the deep clean included cleaning the brakes up, cleaning the chain, changing the oil, changing the coolant and checking everything over. I have a new 2t enduro bike which I have lockwired the throttle cable at both ends to prevent stuck throttle trauma, so i did this to the gas gas too. google earth tells me that the trial tomorrow is in a load of chalk. slimetastic :-] 2 Quote Link to comment Share on other sites More sharing options...
mr neutron Posted November 24, 2013 Report Share Posted November 24, 2013 (edited) In a load of "chalk"??? Hmmm. One of my favorite fishing writers, Roderick Haig-Brown, a Brit, used to write about fishing in "chalk streams"..... Never understood that either.... At any rate, I hope you can find traction & do well tomorrrow, Andrew! On my bike, I fixed a flat on the front wheel today, and greased my steering head bearings. Those tasks went really well. Then, in a fit of stupidity I suppose, I pushed my luck & tried changing the fork oil. I now have no damping whatsoever. Forks bottom out & top out easily, and behave as if there is no hydraulic restriction at all. Did some reading here, and determined I probably need to pull the cartridge & fill it. Sometimes I can't believe how I can take a simple thing I've done easily enough on other bikes, and totally screw it up..... Jimmie Edited November 24, 2013 by mr neutron Quote Link to comment Share on other sites More sharing options...
guys Posted November 24, 2013 Report Share Posted November 24, 2013 On 11/24/2013 at 5:13 AM, mr neutron said: In a load of "chalk"??? Hmmm. One of my favorite fishing writers, Roderick Haig-Brown, a Brit, used to write about fishing in "chalk streams"..... Never understood that either.... At any rate, I hope you can find traction & do well tomorrrow, Andrew! On my bike, I fixed a flat on the front wheel today, and greased my steering head bearings. Those tasks went really well. Then, in a fit of stupidity I suppose, I pushed my luck & tried changing the fork oil. I now have no damping whatsoever. Forks bottom out & top out easily, and behave as if there is no hydraulic restriction at all. Did some reading here, and determined I probably need to pull the cartridge & fill it. Sometimes I can't believe how I can take a simple thing I've done easily enough on other bikes, and totally screw it up..... Jimmie It's not your fault, I've got the same problem. It shouldn't be so difficult to change fork oil, bad design i m o 1 Quote Link to comment Share on other sites More sharing options...
mr neutron Posted November 24, 2013 Report Share Posted November 24, 2013 Thanks, Guys. Granted, when they work, they do a fine job, but I've still came up with a couple of reasons "not-to-like" the Marzocchi forks right now.... I have a broken rebound adjuster on these forks. It broke the very first time I tried to turn it, after having the bike for only a day or two. I'm told I need to buy the entire cartridge to fix this deal. Now, with the cartridge needing removed/filled/primed, it makes me leery of even putting a wrench on the goofy thing....... What brand of forks does your Monty have, out of curiosity? And they have the same sorta deal? Amazing.... Jimmie Quote Link to comment Share on other sites More sharing options...
guys Posted November 24, 2013 Report Share Posted November 24, 2013 No, I also have a GasGas. But replace the entire cartridge? That's ridiculous, the adjuster is a simple aluminium tube with an o-ring at the end. Maybe you can find a second hand one from that guy that breaks up trial bikes for parts... Quote Link to comment Share on other sites More sharing options...
totty79 Posted November 24, 2013 Report Share Posted November 24, 2013 Today I discovered why the front brake lever clicked occasionally - a very mangled circlip fell out. I also replaced the front caliper as someone had butchered two pistons jamming them in the old one. You've got to love previous owners bodges to brakes. 1 Quote Link to comment Share on other sites More sharing options...
shipdamite Posted November 25, 2013 Author Report Share Posted November 25, 2013 On 11/24/2013 at 5:13 AM, mr neutron said: In a load of "chalk"??? Hmmm. One of my favorite fishing writers, Roderick Haig-Brown, a Brit, used to write about fishing in "chalk streams"..... Never understood that either.... At any rate, I hope you can find traction & do well tomorrrow, Andrew! On my bike, I fixed a flat on the front wheel today, and greased my steering head bearings. Those tasks went really well. Then, in a fit of stupidity I suppose, I pushed my luck & tried changing the fork oil. I now have no damping whatsoever. Forks bottom out & top out easily, and behave as if there is no hydraulic restriction at all. Did some reading here, and determined I probably need to pull the cartridge & fill it. Sometimes I can't believe how I can take a simple thing I've done easily enough on other bikes, and totally screw it up..... Jimmie Hi Jimmie I underestimated the terrain; chalk and clay rendered wheels inoperable! it was so slick, sticky and plactic that everything jammed up, my wheels turned to near solid saucers and my boots turned to platforms. so, after the first section (0) everything wents tits up pretty quickly .......... didnt even finish the 1st lap - my riding comrades and I stopped and retired. took an hour to blast the stuff off the bike before it set. I hope that you got the forks sorted out in the end. cheers Andrew Quote Link to comment Share on other sites More sharing options...
shyted Posted December 18, 2013 Report Share Posted December 18, 2013 Hello Ship ,how's it going ? Well not rode since the start of the second week of October due to being stuck at work through bad weather. Got off last Saturday afternoon only to endure a 15&1/2 hour boat journey in 25 foot waves .Sick as a salty sea dog . Now stripped GasGas down and removing a partially dis assembled motor from the frame . Bore Good. Piston and rings good Little end,slight play, Big end no play or noise, Mains no play but starting to make noise, When you consider it's almost 14 years old and there's no evidence what so ever of prior dis assembly , that's bloody good! Photo's to follow. Ted 1 Quote Link to comment Share on other sites More sharing options...
thats_a_five Posted December 18, 2013 Report Share Posted December 18, 2013 On 11/23/2013 at 4:21 PM, shipdamite said: cleaned the bike to get it dirty again at a trial tomorrow. the deep clean included cleaning the brakes up, cleaning the chain, changing the oil, changing the coolant and checking everything over. I have a new 2t enduro bike which I have lockwired the throttle cable at both ends to prevent stuck throttle trauma, so i did this to the gas gas too. google earth tells me that the trial tomorrow is in a load of chalk. slimetastic :-] Do you have the Domino throttle? Most people say to NOT safety wire the cable to the grip end. They are designed so that in the (rare?) case that a rider comes off the bike and it lands on the throttle end, you can simply grab the cable and yank it out of the housing. The cap flies off, the pivot wheel may fall out but when you let go, it allows the cable to go slack so the carb slide can go back to idle before the motor goes "boom." You might want to reconsider the safety wire. I know I did after someone smarter than me explained this. 2 Quote Link to comment Share on other sites More sharing options...
tltel Posted December 18, 2013 Report Share Posted December 18, 2013 On 12/18/2013 at 9:34 AM, shyted said: Hello Ship ,how's it going ? Well not rode since the start of the second week of October due to being stuck at work through bad weather. Got off last Saturday afternoon only to endure a 15&1/2 hour boat journey in 25 foot waves .Sick as a salty sea dog . Now stripped GasGas down and removing a partially dis assembled motor from the frame . Bore Good. Piston and rings good Little end,slight play, Big end no play or noise, Mains no play but starting to make noise, When you consider it's almost 14 years old and there's no evidence what so ever of prior dis assembly , that's bloody good! Photo's to follow. Ted You would be lucky to find that in a 14 year old Beta, from what i have heard. TLTEL 1 Quote Link to comment Share on other sites More sharing options...
shipdamite Posted December 22, 2013 Author Report Share Posted December 22, 2013 (edited) On 12/18/2013 at 10:22 AM, thats_a_five said: Do you have the Domino throttle? Most people say to NOT safety wire the cable to the grip end. They are designed so that in the (rare?) case that a rider comes off the bike and it lands on the throttle end, you can simply grab the cable and yank it out of the housing. The cap flies off, the pivot wheel may fall out but when you let go, it allows the cable to go slack so the carb slide can go back to idle before the motor goes "boom." You might want to reconsider the safety wire. I know I did after someone smarter than me explained this. Thank you; no more lockwire to the throttle! it is the domino one you describe (where as the domino on my endure bike has the screw down cover) I have left the carb end lockwired though. to try and prevent throttle jamming if dropped, I have cut the end of the grip and slid the throttle onto bar so you can see 5mm of bar end. I have then used a washer - slightly larger diameter than the throttle and grip - then made a bar end stop of bolt, washer, rubber tube then a nut so when inserted into bar end and tightened, the nut winds up then expands the rubber tube against the inside of the bar end .......... its worked so far! Edited December 22, 2013 by shipdamite Quote Link to comment Share on other sites More sharing options...
shipdamite Posted December 22, 2013 Author Report Share Posted December 22, 2013 On 12/18/2013 at 9:34 AM, shyted said: Hello Ship ,how's it going ? Well not rode since the start of the second week of October due to being stuck at work through bad weather. Got off last Saturday afternoon only to endure a 15&1/2 hour boat journey in 25 foot waves .Sick as a salty sea dog . Now stripped GasGas down and removing a partially dis assembled motor from the frame . Bore Good. Piston and rings good Little end,slight play, Big end no play or noise, Mains no play but starting to make noise, When you consider it's almost 14 years old and there's no evidence what so ever of prior dis assembly , that's bloody good! Photo's to follow. Ted Hi Ted - sooner you than me with that boat ride! pleased to read that the motor is in good shape ...... i'll keep feeding mine nice oil and keep my fingers crossed .................... Quote Link to comment Share on other sites More sharing options...
shyted Posted December 23, 2013 Report Share Posted December 23, 2013 (edited) Just got back to work . Delay with flight out of the shetlands after take off.The chopper had a malfunction. Interesting to see that the main bearings on the bike are Koyo.Thought they might have been european.Another glimse and they're made in the UK! Will put pictures up tomorrow night . Sending the case's to Triple S in Bingley for painting and the crank is off to Grampian motors for new pin,big end and rod. So today i have a GasGas Question , if you had the cash would you buy a 2014 bike,new.One you've seen for sale ,a 2012 model or a 2010 that needs a little TLC. Think before you answer lad's and lasses. Iv'e put the idea of a Beta out of my head . The main reason ,pathetic i know ,but why am i seeing plenty of 2013 Betas for sale in mint condition and no 2013 Gassers and Lampkin jumped ship from Beta to GasGas . Oh Yes MERRY CHRISTMAS to the lot of you wether you like it or not and i hope you stay in good health! A really Christmasy Shyted Edited December 23, 2013 by shyted Quote Link to comment Share on other sites More sharing options...
