What Did You Do To Your Gas Gas Today?
shipdamite
  • 3 weeks later...
  • 2 weeks later...
Nice looking bike for the age!
Did today:
New oil
New airfilter
New front fork oil+dustseal+seal
New front fork protectors and frame protector
New front disk protector
New steering pad
New grips
And some here and there maintainance.
Edited by crazybond700
I don't think they have it. The 2/5 gearis a single piece that includes the part missing the tooth and the gear "on top" of it. I have tried many places andbit just does not seem to exist. I am waiting for responses from 3 sources still. So fingers crossed!
Fitted new rear wheel bearings, air filter, front mudguard, fresh gear oil and a smaller rear sprocket tonight, will be interesting to see tomorrow how much difference going from a 10-48 to a 10-42 will do to my riding on TXT Pro 200.
Edited by glynn
The Unicorn has been found!  (warning incoming "advertisement")  The wonderful folks at Jack's Cycles were able to locate a gear for me.  it is a used gear but the condition is excellent.  There are of course very mild witness marks where the gears mesh, they look better than the marks on my current one.  And it has all of it's own teeth!
I will be replacing the bushings in the gear with new, so it should ride on the shaft better and last longer.  (I think)
As far as I know this is the first Gearbox issue this bike has had and it's 13yrs old.  I know the previous owner well and he had it from new (he was not exactly gentle on the bike).  So I would think this other gear should last quite some time.
  • Like 2
  • 3 weeks later...
OK here she is.................. The Old BAGG
OK she ain't exactly pretty but she is mine.
I am more of a form before fashion type of rider so all the upgrades etc.. are on the inside.
here be the list.
Replaced:
Dog bones and bearings
Shock Spherical bearings
2/5 gear (broke a tooth)
kickstarter stop
Countershaft bearings
Countershaft bushing and O-rings
Piston, rings, wrist pin, small end bearing
all associated gaskets (of course)
Spark plug
front mud guard brace (on order)
Tires (on order)
Foot Pegs (S3 Hard rock steel foot pegs)
Rear brake pads
Grips
Small O-ring fuel cap (on flip lever stem)
Kill Swich (Jitsie Lanyard type)
Rebuild:
Front brake caliper
Front brake master cylinder
Clutch master cylinder
Clean and lube/ fluids:
Air filter
Swing arm bearings
lube chain
Gearbox oil
coolent
Remove:
pesky lip on the underside of rear fender that never seemed to stay hooked over the air filter/seat assembly.
Edited by zippy
here be the list.
Replaced:
kickstarter stop
Spark plug
Tires (on order)
Rear brake pads
Grips
Rebuild:
Front brake caliper
Air filter
Swing arm bearings
lube chain
Gearbox oil
coolent
Remove:
Cant wait to see you go over its bars again.
--Biff
