shercoben12 Posted December 18, 2012 Report Share Posted December 18, 2012 hi, i am getting some clutch and brake resivior covers for christmas and was wondering if i have to bleed the systems agian when i take the old ones off? thanks, ben Quote Link to comment Share on other sites More sharing options...
p@ul250 Posted December 18, 2012 Report Share Posted December 18, 2012 Hi Ben No you will not need to bleed the brakes after changing the cover's. Just make certain that the reservoirs are level when you remove the old cap and have some water handy to rinse off any spills as soon as you have fitted the new one's. Brake fluid eats paint/plastics. Quote Link to comment Share on other sites More sharing options...
lee99780 Posted December 19, 2012 Report Share Posted December 19, 2012 Make sure your covers are clean before you remove and no dirt or dust falls in your reservoirs too Ben! Quote Link to comment Share on other sites More sharing options...
shercoben12 Posted December 19, 2012 Author Report Share Posted December 19, 2012 Thanks Quote Link to comment Share on other sites More sharing options...
sting32 Posted December 21, 2012 Report Share Posted December 21, 2012 Ben, I have installed the S-3 versions of these covers on my bikes: I move them to new bikes sometimes if they are still not all scratched and stuff... BUT the biggest problem I have is they leaked... I figured it out though.... You cant tighten the aluminum ones I have at least, as tight. I'm talking about up to MAYBE 1/6th of a rotation of the screwdriver less tight when you tight? you will have to play with it if you have the problem I had. Older bikes, I didnt seem to have this problem. So just beware, but it could just be "just me". sucks to figure it out on the day of the trials and clutch master cylinder is "suddenly" dry. Quote Link to comment Share on other sites More sharing options...
shercoben12 Posted December 22, 2012 Author Report Share Posted December 22, 2012 Ben, I have installed the S-3 versions of these covers on my bikes: I move them to new bikes sometimes if they are still not all scratched and stuff... BUT the biggest problem I have is they leaked... I figured it out though.... You cant tighten the aluminum ones I have at least, as tight. I'm talking about up to MAYBE 1/6th of a rotation of the screwdriver less tight when you tight? you will have to play with it if you have the problem I had. Older bikes, I didnt seem to have this problem. So just beware, but it could just be "just me". sucks to figure it out on the day of the trials and clutch master cylinder is "suddenly" dry. my mate has the s3 ones on his 08 which is the same bike as mine and he has no problems. so maybe its just the newer bikes? thanks for the advice though ben Quote Link to comment Share on other sites More sharing options...
sting32 Posted December 26, 2012 Report Share Posted December 26, 2012 Ben, it was the clutch side, if that matters... We had bought these covers for the my dads 2010 when we unboxed it. when I moved from the 10, he moved to the 2012, so I took them to the 11. still just saying when you get done installing the caps, loosen the levers, turn upside down best you can, see if they leak. Mine were dry one afternoon, that is when I was like What the heck? I fiddled for a while, finally I just decided to try not as tight... So, didnt tighten them quite as much as I can stock covers, and I think they quit leaking for me. I had all but given up and almost put stock ones back on. not everyone will have this problem, maybe no one else will, so just sayin... I honestly need to remind myself to check to see if I have lost fluid, since then. Quote Link to comment Share on other sites More sharing options...
shercoben12 Posted December 26, 2012 Author Report Share Posted December 26, 2012 Ben, it was the clutch side, if that matters... We had bought these covers for the my dads 2010 when we unboxed it. when I moved from the 10, he moved to the 2012, so I took them to the 11. still just saying when you get done installing the caps, loosen the levers, turn upside down best you can, see if they leak. Mine were dry one afternoon, that is when I was like What the heck? I fiddled for a while, finally I just decided to try not as tight... So, didnt tighten them quite as much as I can stock covers, and I think they quit leaking for me. I had all but given up and almost put stock ones back on. not everyone will have this problem, maybe no one else will, so just sayin... I honestly need to remind myself to check to see if I have lost fluid, since then. checked and they dont leak! Quote Link to comment Share on other sites More sharing options...
cursed Posted December 31, 2012 Report Share Posted December 31, 2012 BUT the biggest problem I have is they leaked... Try a very light smearing of silicone grease on the o-ring (take it off to lube & reinstall). You should always do this anyway to any o-ring. Quote Link to comment Share on other sites More sharing options...
