jej Posted December 19, 2012 Report Share Posted December 19, 2012 My 2000 (Bultaco) Sherco has a problem with returning the gear lever to center. Having removing the cluch the spring is OK but there seems to be slight wear / damage on the selector, Does anyone know if there is anything hung on the shaft inside the gearbox before I pull it through from the gear lever side? Don't want to split the cases if selector forks or anything is going to drop off of it. Quote Link to comment Share on other sites More sharing options...
copemech Posted December 19, 2012 Report Share Posted December 19, 2012 Should pull out no problem. Quote Link to comment Share on other sites More sharing options...
