Ty 250 Twin Shock Front Brake(Lever Goes Hard)
broony
Was out getting the TY ready for Boxing Day and riding round the
garden and after using the front brake the front would lock up
with the brake lever released and the lever was solid.Then the
next time I used it the lever was fine,it has done this previously
at events but has never locked the wheel before.It has a brand new
cable and the shoes are good(could the drum be worn needing over-
sized shoes).Any ideas ???
cheers the noo Brian
Is it a mono brake?/ If so they had a tendency to lock front brakes without warning. Can be dangerous. If it's not a mono enclosed type, then I'd strip and clean the brake, moisture may have got in, check for abnormal wear when it's apart, centralise it when building back up.
Edited by andy m
Usually a quick and satisfying fix. First check your "new" cable. Some new OEM cables have a tight spot where the wire runs through the steel tube at the bottom, might need to be bent slightly to give a smoother run. The TY brake plates get a crud build up in the actuating pivot, combination of mud and old grease. Remove and clean. Also clean the contact point on that cam and also the shoes where they touch the cam.
Tony
Like others, I suspect it is the pivot shaft binding in the brake plate. A good cleaning and new grease would fix that. Here are a couple more ideas.
When the brake lever pivots, the flats on the shaft act on the shoes to spread them.
1) If the shaft rotates excessively the end of the shoes will not be on the flats but on the major OD of the shaft. They will not release.
2) If a spring has broken or come off during assembly, there may not be enough tension to pull the shoes back together.
3) If the shoe has come out of position at either end, it might allow the shaft to rotate past the flats.
4) If the lever is not on the correct position on the spline, it may allow the cable to bottom in the end fitting and bind inside the cable.
A good strip, clean, lube and careful reassembly should solve the problem. Good luck and let us know what you find.
Stripped the front brake out today,gave the drum and shoes
a rub down with emery paper(a wee bit rusty),cleaned and
lubed the pivot.Put it back together and centralized the shoes.
Rode it round the garden and no lock ups will see how it goes
on Boxing day.
