thecasual5 Posted December 22, 2012 Report Share Posted December 22, 2012 There's a kiehin carb for a xer pwk 28 can u use them on a gasser with the right jets. How much would a conversion like this cost Quote Link to comment Share on other sites More sharing options...
laser1 Posted December 22, 2012 Report Share Posted December 22, 2012 Aside from the cost of the carb, you would either need to buy a raga intake manifold or Jitsie adapter to convert the bike from a Dellorto 26mm to the Keihin PWK 28mm inlet. You would also need a Keihin type throttle cable. Quote Link to comment Share on other sites More sharing options...
tony27 Posted December 23, 2012 Report Share Posted December 23, 2012 PWK28 carbs off 80/85cc mx bikes seem to list on ebay from 70gbp/100usd upwards but who knows what throttle slides they use, jets & needles are fairly cheap & easy to buy but the slides aren't cheap-somewhere in the 60gbp range from splatshop. Probably easier/cheaper to buy a carb & manifold kit that is already set up rather than buy the individual parts Complete setup http://www.splatshop.co.uk/Gas Gas-raga-reed-block-and-keihin-pwk-28-carburettor.html Manifold/reedvalve only http://www.splatshop.co.uk/Gas Gas-raga-reed-block-assembly-for-kehin-pwk-28.html As you can see it works out a lot cheaper to buy the whole lot in 1 go than getting a carb & rejetting it as well as buying the manifold/reed valve Quote Link to comment Share on other sites More sharing options...
