kjdonovan Posted December 27, 2012 Report Share Posted December 27, 2012 Hi Guys, I have a question. I picked up a 72 Cota 123 this past summer for my wife; she loves everything about the bike except the shifting. Trying to get it into 2nd or 3rd takes multiple attempts and each time I change the oil, it looks like I struck gold, lots and lots of shiny flecks of metal mixed with the oil. So I figured with winter here I would tear it down and go through it. I suspect over the next few months I will have lots of questions. And my first is; what is the correct way to split the cases on this engine? I don’t want to just open in up and have everything spill out, I know on other bikes I have worked on you should keep one side stationary and lift off the other, to keep the gears and shafts intact. So with this bike do I keep the mag side stationary and lift off the clutch side or keep the clutch side stationary and lift off the mag side? Thanks, Kevin Donovan Foster, RI USA Quote Link to comment Share on other sites More sharing options...
stillers1965 Posted December 28, 2012 Report Share Posted December 28, 2012 Clutch oil or gear oil bad ? Quote Link to comment Share on other sites More sharing options...
lineaway Posted December 28, 2012 Report Share Posted December 28, 2012 Most of the shifting mechanism can be had by just the clutch cover. Quote Link to comment Share on other sites More sharing options...
andrewb Posted January 6, 2013 Report Share Posted January 6, 2013 Split the cases a few times on my 123 in the 70's but don't remember having to remove one half and leave the other stationary. If you do split the cases though I would recommend replacing all of the circlips on the gear shafts as I had a similar problem. These gearboxes (I was told at the time) were notoriously brittle, however once I changed the circlips no more selection problems or trouble at all. Quote Link to comment Share on other sites More sharing options...
zerorev3rev4 Posted January 7, 2013 Report Share Posted January 7, 2013 also bear in mind there is a wrong and right way round for circlips you may need a magnyfying glass to work this out ,gettint it wrong will cause them to pop off Quote Link to comment Share on other sites More sharing options...
andrewb Posted January 8, 2013 Report Share Posted January 8, 2013 I must have been a very lucky 14 year old. I hadn't been told that one! Quote Link to comment Share on other sites More sharing options...
zerorev3rev4 Posted January 8, 2013 Report Share Posted January 8, 2013 nor has plenty 50plus yr olds Quote Link to comment Share on other sites More sharing options...
