guys Posted December 30, 2012 Report Share Posted December 30, 2012 Hi everybody I've had two chain tensioners (brand: Ariete) that broke in to pieces in a very short time although the discription says the following: 'A replacement trials chain tensioner spare pad made from the much more durable silicon rubber More expensive than the standard rubber item, but will pay back with much longer life' So here's my question: What brand do you guys use, are the S3 any good? Quote Link to comment Share on other sites More sharing options...
b40rt Posted December 30, 2012 Report Share Posted December 30, 2012 I use hard plastic blocks, cut to size. They initially wear quickly but once in shape last well. Machine shops can usually supply off cuts. 1 Quote Link to comment Share on other sites More sharing options...
old trials fanatic Posted December 30, 2012 Report Share Posted December 30, 2012 I just use a universal chain tensioner pad. Cost £4.00 and never had to replace one yet. 1 Quote Link to comment Share on other sites More sharing options...
guys Posted December 30, 2012 Author Report Share Posted December 30, 2012 On 12/30/2012 at 7:33 PM, b40rt said: I use hard plastic blocks, cut to size. They initially wear quickly but once in shape last well. Machine shops can usually supply off cuts. Hmmm, might be a good idea. Lots of different kinds of plastics at work available... Thanks Quote Link to comment Share on other sites More sharing options...
lineaway Posted December 30, 2012 Report Share Posted December 30, 2012 The ones that broke usually last a long time. I would look at `what` caused them too last such a short time? Quote Link to comment Share on other sites More sharing options...
guys Posted December 30, 2012 Author Report Share Posted December 30, 2012 On 12/30/2012 at 7:44 PM, lineaway said: The ones that broke usually last a long time. I would look at `what` caused them too last such a short time? I don't know. because they're crap? The first one only lasted 3 months, wore down to the metal tubes and the "bridge" (the upper part) broke off. Yesterday i mounted the second one, and after 2 hours of training it breakes in the middle, between the two bolts. Quote Link to comment Share on other sites More sharing options...
lineaway Posted December 30, 2012 Report Share Posted December 30, 2012 I`ve never had problems with them. Can`t go wrong with a solid plastic block. That should solve the problem! Quote Link to comment Share on other sites More sharing options...
outlaw dave Posted December 30, 2012 Report Share Posted December 30, 2012 Are you running your chain too tight? Quote Link to comment Share on other sites More sharing options...
guys Posted December 30, 2012 Author Report Share Posted December 30, 2012 On 12/30/2012 at 8:35 PM, outlaw dave said: Are you running your chain too tight? Nope. (one finger between the tensioner and the swing-arm) Quote Link to comment Share on other sites More sharing options...
b40rt Posted December 30, 2012 Report Share Posted December 30, 2012 2 Quote Link to comment Share on other sites More sharing options...
guys Posted December 30, 2012 Author Report Share Posted December 30, 2012 On 12/30/2012 at 8:46 PM, b40rt said: Quote Link to comment Share on other sites More sharing options...
zippy Posted December 31, 2012 Report Share Posted December 31, 2012 This is what I prefer to use. http://www.vmar.com/chain-guide.html In an emergency I made up a block for a buddy that was riding at the house. I have a sheet of teflon that I cut a strip out of and had to sandwich 3 pieces together to get it wide enough and then a little quick "machining" with a router, a dremel, and a drill and viola he had a rub block and we could continue to ride. I think he will be using that for quite some time........ 1 Quote Link to comment Share on other sites More sharing options...
guys Posted January 2, 2013 Author Report Share Posted January 2, 2013 Made myself a chaintensioner from a block of Ertalon LFX, a internally lubricated cast nylon... I'll post a picture and let you guy's know how it works out... Quote Link to comment Share on other sites More sharing options...
guys Posted January 4, 2013 Author Report Share Posted January 4, 2013 Pictures of my home-made chaintensioner (and rear "wave"- brakedisc): http://www.trialscentral.com/forums/gallery/album/118-chain-tensioner-and-wave-brakedisc-montesa-4rt/ Quote Link to comment Share on other sites More sharing options...
old trials fanatic Posted January 4, 2013 Report Share Posted January 4, 2013 You made a really nice job of that. well done 1 Quote Link to comment Share on other sites More sharing options...
