frogger Posted January 2, 2013 Report Share Posted January 2, 2013 Does anybody have access to a 2013 TXT Pro 300 wiring diagram? Easiest place to pick up power to run electronic clocks from? Quote Link to comment Share on other sites More sharing options...
tankygsy Posted January 3, 2013 Report Share Posted January 3, 2013 Not seen a diagram for the 2013 model but I no doubt suspect you will have ha cable coming up from the flywheel case via a ac/dc rectifier which goes to a 12 volt regulator. This will go on to supply the cooling fan and you can tap into this if there isn't all ready a spare terminal (that would normally be used for lights and instrument panel. Won't be too hard to find with a volt meter. 1 Quote Link to comment Share on other sites More sharing options...
