pat52 Posted January 2, 2013 Report Share Posted January 2, 2013 I have lots of play in the rear suspension of my 05 txt pro, i have changed the linkage kit and understand i need to replace the "rose" joint/ bearing. I have been quoted Quote Link to comment Share on other sites More sharing options...
bob_m Posted January 3, 2013 Report Share Posted January 3, 2013 The bearing number should be listed in the parts manual available on the Gas Gas website in the TECH section. I have gotten wheel bearings from VXB.com for my 1996 JTR270 but they are in California US. They also have some of the swing arm bearings (HK1512 & HK1516) but without the double side seals. Make sure you get them with double seals if they have seals in the factory ones. You could try Ebay too. Quote Link to comment Share on other sites More sharing options...
b40rt Posted January 3, 2013 Report Share Posted January 3, 2013 Have you looked on the bearing for a number ? Quote Link to comment Share on other sites More sharing options...
laser1 Posted January 3, 2013 Report Share Posted January 3, 2013 All-balls sells them. Quote Link to comment Share on other sites More sharing options...
