breagh Posted January 14, 2013 Report Share Posted January 14, 2013 Got the above,anyone ever have to retard one or am i getting too old. It's not the initial pick up which is quite perky,but mid range is instant. Cheers. Quote Link to comment Share on other sites More sharing options...
fatbastard Posted January 14, 2013 Report Share Posted January 14, 2013 I thought if anyone knew about Retards it would be you. Sorry cant be of any help though . Quote Link to comment Share on other sites More sharing options...
Andy Posted January 14, 2013 Report Share Posted January 14, 2013 What's happened to your DBF pal? Quote Link to comment Share on other sites More sharing options...
fatbastard Posted January 14, 2013 Report Share Posted January 14, 2013 He took up cycling in Lycra , Allan's my new side kick. Quote Link to comment Share on other sites More sharing options...
laser1 Posted January 14, 2013 Report Share Posted January 14, 2013 You could Richen the needle as well. If the jetting is spot on now, richer will slow down the pickup a bit. Quote Link to comment Share on other sites More sharing options...
grant8 Posted January 14, 2013 Report Share Posted January 14, 2013 Think your just getting to old Alan, you would be better of on jocks dinosaur? Quote Link to comment Share on other sites More sharing options...
demmo Posted January 14, 2013 Report Share Posted January 14, 2013 Tie a knot in the throttle cable so you can't rev it so much ! Quote Link to comment Share on other sites More sharing options...
breagh Posted January 14, 2013 Author Report Share Posted January 14, 2013 At least laser has a constructive suggestion,the rest of you wouldn't know a trials bike if it run you over. I would be reluctant to touch carb settings as it runs so nicely. I was hoping someone had retarded (Good word in this company)one,and how it went. No more replies from Jockland please. Quote Link to comment Share on other sites More sharing options...
fatbastard Posted January 14, 2013 Report Share Posted January 14, 2013 I'm not being funny but have you run it past Birkett's . He might have a solution for you I've phoned him on a couple of occasions and was really helpful. Quote Link to comment Share on other sites More sharing options...
godzilla Posted January 14, 2013 Report Share Posted January 14, 2013 Birkett's set my bike up from new to be soft, they knocked the timing back. http://www.shercousa.com/pdfs/sherco_ignition_timing_guide.pdf 1 Quote Link to comment Share on other sites More sharing options...
copemech Posted January 15, 2013 Report Share Posted January 15, 2013 You on about a Rotax powered SAcorps? Yes, kick the timing back all the way! Quote Link to comment Share on other sites More sharing options...
breagh Posted January 15, 2013 Author Report Share Posted January 15, 2013 Apologies,it's a 2011. I didn't make that clear. Quote Link to comment Share on other sites More sharing options...
demmo Posted January 15, 2013 Report Share Posted January 15, 2013 If it's the auld sherco engine, pull the flywheel off, mark where the stator is, slacken the 3 bolts, then move the stator plate about 5mm, rebuild and try it out. It made a difference to my 04, 06, and 09 bikes. 1 Quote Link to comment Share on other sites More sharing options...
copemech Posted January 16, 2013 Report Share Posted January 16, 2013 Oh it's the Sherco motor then! Yep, Demmo is right. There should be a mark on the stator plate that aligns with the right edge of the casting web on top. I usually tell folks , a change(counter rotation to retard or slow) of 1-2mm(mild), 3-4mm(mid) or 5-6mm(most), so adjust accordingly. Seems a 1mm change is not really enough to tell. 1 Quote Link to comment Share on other sites More sharing options...
ridgrunr Posted February 11, 2013 Report Share Posted February 11, 2013 If you are wanting to slow it down a bit, you might put a slow turn throttle on it, that is if you have a fast one on there now. The white tubes are the fast one and the black are slow. Quote Link to comment Share on other sites More sharing options...
