Cota 348 Engine #
gasgasstu
The number should be the same as the frame. The casing have other numbers that are matching numbers as the cases where graded in the factory and matched together then have the same number stamped on the two halfs of the case. These numbers are usually on the engine mounting lugs and usually are a two digit number.
  • 2 weeks later...
